Hi all,
As usually there is some problem with the car, a week after cleaning the intake when i leave the car at idle the Engine light goes on.
The error 92 should be "Throttle valve position feedback system"..
I really have no idea what it could be, i suspect it might be something with the TPS, do you suggest to just replace it or is there some other way to try fix it ?
Thx in advance!
1.8 GDi Error code 92 - Fehlercode 92
starsky 25.09.2010, 21:20
3 Beiträge • Seite 1 von 1
- 2016 Zugriffe,
Beobachter: starsky
Sorry my english will not be perfect but i try.
Well first of all, if i get you right, you cleaned the Air Intake right?
If you have done this it might be that you killed your sensor for the consuming of air ( in german "Luftmengenmesser" ). If i remember right there is an electronic plug on the air intake. Under the plug the sensor is placed.
I would suggest to change that one in a garage somewhere!
Btw: It can seriously harm your engine if that part is broken.
Also btw. Where did you got the code from?
MfG
Alex
MfG
Alex
Mitsubishi Carisma 1,8GDI Avance
"Der Gründe Blitz"
Frontsystem MB-Quart Discus 2-Wege
Hecksystem MB-Quart Discus Coax
Endstufe 6-Kanal 850 Watt JBL
Sub 350 Watt JBL
"Der Gründe Blitz"
Sub 350 Watt JBL
- Anfänger
- 17.10.2007
- 9 Themen, 93 Beiträge
- 0x erhalten, 1x gegeben
starsky hat am 25.09.2010, 21:20:Hi all,
Thx in advance!
Maybe you should look for the plug at the air flow-sensor, as AlexanderThimm suggested. It could just be a slack joint.
I had a similar error when I forgot to plug in the plug for the air flow-sensor after attaching a new air filter.
Dieses Thema wurde verschoben: aus ⁉️ Carisma Probleme, nach 💨 Benzin-Motor: MPI und GDI, von carisma, am 12.02.2017, 16:01.
